Hawk 555 Жалоба Опубликовано 19 Июля 2012 Вот думаю приобрести себе вот такую железку. Features: Suitable for cars, vans, trucks, bikes, etc.You this Purcnase is Real Time GPS Vahicle Tracker Drive Include Free Use Latest GPS Tracker Software. No Contract, No Activation Fee, No Software use Fee. Can Remote control car power and oil More safety and convenience, by (running on a personal computer) remote control software can cut off the vehicle oil and the circuitalso can be connections the original vehicle are vibration sensors and automotive door control switch. It can help you track anything such as your car, boat and other vehicle in time. You will not worry about losing them forever. It is working based on existing GSM/GPRS network and GPS satellites, this product can locate and monitor any remote targets by SMS or internet. Please visit my store to buy it now. Applications: Global positioning Real-time monitoring Vehicle locating Timing tracking Cutting off power and oli by remote control Vehicle rental / Fleet management etc Function introduction: 1、Support bothGPS / GSM station positioning ways. Support SMS/GPRS/Internet Network data transfer (GPRS/Internet instructions in CD enclosed) Support GPRS on-line and the line re-connected automatically. Support work based on existing GSM/GPRS network.. Support configuration by remote terminal. SOS alarm. Support for point-to-point, point to group,group-to-group monitoring. Set multiple functions of security, positioning, monitoring surveillance, emergency alarms and tracking in its entirety. Remote control can be deployed in and disarm Remote control vehicle oil and circuit Connect the original vehicle anti-theft or a vibration sensor, and keyless entry alarm Main functions: Positioning and Tracking: Through the on-line Positioning Platform or the cell phone to locates at times, and get the working status. You can choose the Positioning Platform by yourself. Triggering Emergency Alarm: When there is a emergency happened on the vehicle, you can put on the button and the installed unit will send out alarm to the authorized numbers. Remote controlling oil and circuit: you can control the oil and circuit via the unit by SMS in anywhere and anytime. Remote Monitoring: In anywhere and anytime, call the phone number in the unit, when it connects, you can monitor the sound around 5 meter. Movement Alert: Send SMS to the unit to start the movement alert function. When the vehicle is moving, the unit will send the movement alert to all authorized numbers. Overspeed Alert: Send SMS to the unit to start the movement alert function. When the vehicle is overspeed, the unit will send the overspeed alert to all authorized numbers. Geo-fence: Set up a geo-fence for the unit to restrict its movements within a district. The unit will send the message to all authorized numbers when it breaches the district. Restart the unit: send SMS to resume the default of unit. Auto Track: You can set up auto track by SMS or on-line positioning platform. Mileage statistics; ACC checking; cutting off power and alarm. Compatible with the original anti-theft alarm: It will send SMS alarm after the original anti-theft alarm warning. Modify the IP and Port of Communication Protocol for different on-line positioning platform HOW IT WORKS Simply insert a GSM sim card into the GPS unit. Whenever you call the unit it will respond with the coordinates of its location thru a SMS message. You can then use these coordinates on any mapping software (for example google earth) which will show where exactly the unit is located. With some little setup, you can also have the device to send the data directly to a computer thru GPRS and display its location on a map with our bundled software for real-time location tracking. Of course, you can control your vehicle through our software. For more detailed instruction, you can click the following link to see the menu: General Menu (General setup & tracking thru SMS) Menu for the PC Tracking Application SpecificationSize: 83*54*26mmWeight: 115g Network: GSM/GPRS Band: 850/1800/1900Mhz or 900/1800/1900Mhz GPS chip: SIRF3 chip GSM/GPRS: Simcom300d or Simcom340d GPS sensitivity: -159dBm GPS accuracy: 5m Time to first fix: Cold status 45s Warm status 35s Hot status 1s Voltage of car power system: 12V input Car charger output: Cut off the power and the oil system and control the power system:0V Car power input: Door 0V(Negative trigger)or 12V(positive trigger) ACC: 12Vsensor:0V SOS button:0V Emergency Battery: 3.7V 500mAh Li-ion battery inside Gps vehicle drivce Storage Temp.: -40°C to +85°C Operation Temp.: -20°C to +55°C Humidity: 5%--95% non-condensing Кто-нибудь имел опыт эксплуатации подобного девайса? Цитата Поделиться этим сообщением Ссылка на сообщение Поделиться на других сайтах
sergiospb 30 Жалоба Опубликовано 19 Июля 2012 теперь правительство будет следить за тобой Цитата Поделиться этим сообщением Ссылка на сообщение Поделиться на других сайтах
Sputnic77 5 Жалоба Опубликовано 19 Июля 2012 С какой целью хочешь его купить? Цитата Поделиться этим сообщением Ссылка на сообщение Поделиться на других сайтах
Hawk 555 Жалоба Опубликовано 19 Июля 2012 (изменено) теперь правительство будет следить за тобой Оно и так следит за всеми нами. По мне так очень полезная железка. Можно всегда знать, где находится машина. Да и цена я считаю приемлема. С какой целью хочешь его купить? Что-бы можно было отследить местоположение авто. Был как-то неприятный случай, когда экакуаторщики утащили машину в другое место. Изменено 19 Июля 2012 пользователем hawk2212 Цитата Поделиться этим сообщением Ссылка на сообщение Поделиться на других сайтах
Sputnic77 5 Жалоба Опубликовано 19 Июля 2012 (изменено) Если брать то с автономным питанием например Starline Изменено 19 Июля 2012 пользователем Sputnic77 Цитата Поделиться этим сообщением Ссылка на сообщение Поделиться на других сайтах
wind line 4 Жалоба Опубликовано 19 Июля 2012 Если не нужно постоянно следить за машиной, лучше взять автономный треккер, типа автофон-маяк и т.п, производители заявляют длительность работы в энергосберегающим режиме 3-6 месяцев. Смс послал, ответ с координатами получил. Цитата Поделиться этим сообщением Ссылка на сообщение Поделиться на других сайтах
BigHarry 1 135 Жалоба Опубликовано 19 Июля 2012 В этом вроде тоже есть табарейка, но вроде только в модуле GPS, который судя по всему - отдельно пристегивается Emergency Battery: 3.7V 500mAh Li-ion battery inside Gps vehicle drivce Цитата Поделиться этим сообщением Ссылка на сообщение Поделиться на других сайтах
